1) What flavor of G-Code are you using?
2) Are you using Marlin as your firmware?
3) Are you able to use Octaprint on the Ditto Pro
4) Has anyone put on a heated bed onto the Ditto Pro?
Hi Bobby, here are the answers to your questions:
1) RepRap Marlin Gcode.
2) The DittoPro uses a modified Marlin firmware.
3) Yes, Octoprint should be compatible with the DittoPro.
4) We have heard other users adding a heated bed, but took a lot of modification to make it work.
Log in to join the conversation!
