Rubber Band Cars
  • •   9 years ago
    Engineering Design Process: Rubber Band Cars
    Focus of this project is to explore rubber band car design. Similar to a engineering design process, you’ll need to:
    1. Identify objectives
    2. Identify constraints
    3. Brainstorm ideas
    4. Select a design
    5. Build a prototype
    6. Test your design
    7. Refine your design
    8. Repeat.
    Select from a variety of connectors and wheels to add to the chassis. Printed components can be joined using wooden skewers and locked in place by screwing down #2 3/8” screws.
Suggested Grade
Time Required
Resources Required
Learning Objectives
3-121 Hour
  • Rubber band car printed components
  • Rubber bands (Various sizes and tension)
  • Wood skewers (3-4 mm)
  • Wire clippers / shears
  • Parts assembly and use of hand tools
  • Energy transformation (kinetic / potential)
6-121 Hour
  • Tape measure
  • Design and assemble a rubber band car
  • Measure distance traveled
  • Test and refine car design
  • Communicate the design process and results.
Made one too? We'd love to see it!
I Made One!
  • Be the first to leave a comment!
  • •   9 years ago   •
    3. Brainstorm ideas
    4. Select a design
    6. Test your design
    8. Repeat.
