DittoPro Profile in Cura
  • •   8 years ago
    4
    Hi everyone.
    Our DittoPros are being used in an educational institution. Although Tinkerine Suite is a great software application, we would like to expand the software support we provide to our students. We were thinking of introducing Cura alongside with Tinkerine Suite to our students. Our rational is that we would like our students to be prepared to use a wider variety of printers/software once they leave our institution (and our printers).
    Can someone please share with me the following printer settings in order to prolong our DittoPro printer's lifespan and to continue to utilize our DittoPro printers with Cura (as well as Tinkerine Suite)?
    Printer Settings
    X (Width) = mm
    Y (Depth = mm
    Z (height) = mm
    • Is the Machine Centre zero?
    • which Gcode Flavor works best?
    Print head Settings
    X min
    Y min
    X Max
    Y Max
    • what is the Gantry height
    • what is the nozzle size
    Start Gcode settings. By default Cura selects
    G28 ;Home
    G1 Z15.0 F6000 ;Move the platform down 15mm
    ;Prime the extruder
    G92 E0
    G1 F200 E3
    G92 E0
    Eng Gcode By default Cura selects
    M104 S0
    M140 S0
    ;RETRACT THE FILAMENT
    G92 E1
    G1 E-1 F300
    G28 X0 Y0
    M84
ANSWERS (4)
  • 2
    Hi everyone.
    Printer Settings
    X (Width) = mm
    Y (Depth = mm
    Z (height) = mm
    Print head Settings
    X min
    Y min
    X Max
    Y Max
    G28 ;Home
    ;Prime the extruder
    G92 E0
    G1 F200 E3
    G92 E0
    M104 S0
    M140 S0
    G92 E1
    G1 E-1 F300
    G28 X0 Y0
    M84
    8 years ago   •
  • 0
    Hi Julio, here are some settings that you can use in Cura, but note that we haven't tested these ourselves; these are the settings from Tinkerine Suite so you may have to tweek them to get your prints just right.
    Printer Settings
    X: 215mm
    Y: 160mm
    Z: 220mm
    Machine Center is NOT zero
    Reprap Gcode flavor works best
    Print head Settings
    Not sure what these are referring to.
    Nozzle Size: 0.4mm
    Start Gcode:
    M104 S220
    T0
    G28
    G90
    M106 S0
    G92 E0
    End Gcode:
    G91
    G1 Z0.2 E-4 F2000
    G4 P600
    G28 X0 Y0
    G91
    G1 Z80 F3000
    M106 S0
    M84
    G90
    8 years ago   •   edited   •
  • 1
    Hi Justin. Thanks for the support. I'll test these settings and update this post.
    8 years ago   •
  • 0
    For posterity, the above ending gcode is missing a crucial line. Here's the ending gcode I've seen tinkerine studio generate:
    ;End GCode
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    ;G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    ;G1 Z+0.5 E-5 X-20 Y-20 F12000 ;move Z up a bit and retract filament even more
    G1 Z0.2 E-4 F2000 ;move Z up a bit and retract filament even more
    G4 P600 ; dwell time of 900 ms
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    G91; use relative
    G1 Z80 F3000; drop 80mm
    M106 S0; turn off fan
    M84 ;steppers off
    G90 ;absolute positioning
    Note the G91 line. Without that the gcode will tell the printer to move the bed to 0.5mm instead of moving it to 0.5mm away from its current position. The difference means shoving your freshly printed part into the print head shortly before attempting to move the print head to its home position. And this can be difficult when it has to drag a hunk of plastic stuck to a glass bed which is in turn clipped to a stationary platform. It's not a beautiful sound.
    Anyway, I can confirm that the end gcode in this post works.
  • 0
    Good catch! Indeed the gcode I posted earlier was missing the G91 line. Thanks for sharing your findings!
    8 years ago   •
