Printer: DittoPro-R
Print Time: 1h 10m
Resolution: 300 microns
Support Structure: Yes
Tinkerine Face Shield V3
New design concept. Optimized for 3D printing, but made for scalable fabrication through CNC machining.
A new clip on system for the shield (Thanks Greg from Plasticworks!)
The new clip mechanism is significantly more rigid than the other versions out there. This is probably going to be the mechanism we'll be using moving forward as we can also CNC it as well.
Some design choices had to be made..time saving vs rigidity, It's a fine balance. At ~1hr a frame. It's still pretty good.
A few notes: These will be adjusted on V4
- The radius of the curve is too tight, goggles and glasses may collide. It's good for those with a narrow face.
- The top shield that's linked to the main frame makes the frame non-flexible, will leave some gaps but I like this idea and it prints in 1 go.
- Shield being 30cm tall may be a little too long. This limits movement. Will probably reduce to just below the chin.
Files:
shield.dwg (Hole location may need adjusting from what I recall.)
